Search function not readily visible on mobile view. User needs to click on options to see it.
The search window opens as an overlay on top of the document viewer in the mobile view. Clicking on one of the search results does not close the search window to render the document.
- Can the position of the search option be changed on the toolbar so that it is readily visible on mobile view?
- When user clicks on a search result, the search window should close/collapse and the result should be displayed on the document.
All
NA
NA
