Hello
Amongst the all annotation done on pdf, can we extract the response only  for the comments, and how can we retains/import those extracted response of comment on pdf.
Kindly provide code snippet.
Hello nikhilhill19,
To clarify: you only want to export the annotation replies?
If that’s the case you can filter the annotations you wish to export, then provide that in:
annotationManager.exportAnnotations({
annotList: // your annotation list
Yes I only want to export the annotation replies.
What should I pass inside annotList array?
Hello nikhilhill19,
You would pass in a list of the reply annotations,
annotList: instance.Core.annotationManager.getAnnotationsList().filter((annot)=> annot.isReply() === true)
Best regards
