luigi
1
PDF.js Express Free Viewer
Programmatically in javascript I want “click” or enabled tool button “panToolButton”
Every
nop
nop
system
3
Guides:
APIs:
Forums:
Hi Luigi,
Thanks for your question.
Here is a code snippet to help you enable the panToolButton.
import WebViewer from '@pdftron/pdfjs-express-viewer'
...options
}).then(instance => {
const { Tools } = instance.Core;
const panTool = Tools.ToolNames.PAN;
instance.UI.setToolMode(panTool);
Hope this helps and let me know if this approach works for you.
Thank you,
Dandara
luigi
5
Hi Dandara!!! Sounds good and works perfectly!!! Thanks!!! You win a “paella valenciana”, I’m from Valencia (Spain)
. See you my next problem.
