karin
May 13, 2022, 10:23pm
1
Express plus (free version)
Tools are not showing up on the pdf, after inspecting the elements it is by default set to “closed”
PDF tools usable
every document
import { useRef, useEffect } from "react";
import WebViewer from "@pdftron/pdfjs-express";
const DocumentViewer = () => {
const viewer = useRef(null);
useEffect(() => {
path: process.env.PUBLIC_URL + "/pdfjsexpress",
initialDoc: process.env.PUBLIC_URL + "/pdfjsexpress/demo.pdf"
viewer.current,
).then((instance) => {
return (
<div className="">
<div className="header">React sample</div>
<div className="webviewer" ref={viewer}></div>
</div>
system
3
Guides:
APIs:
Forums:
Hi There,
Thanks for your question to enable the tools header you can use the enableElements
API (API document ). Following is a code snippet for your reference.
useEffect(() => {
viewer.current,
instance.UI.enableElements(['ribbons', 'toolsHeader']);
return (
<div className="">
</div>
Please let me know if this works for you.
Dandara
karin
May 16, 2022, 8:56pm
5
Hey Dandara,
Thanks so much for the prompt response! I am trying that out now.
I spun up the demo version you guys provide on your wesbite but it didnt utilize that method and the toolbars were able to be used there, could you shed some light on how it was able to work there without the explicit use of enableElements?
Thank you,
Karin
May 16, 2022, 9:25pm
6
I believe you are talking about the secondary annotation toolbar, correct?
By default the viewer is set to View
mode which does not have a secondary toolbar. You can programmatically switch it to the Annotate
tab by calling
instance.UI.setToolbarGroup('toolbarGroup-Annotate');
This is what we do in the online demo.
karin
May 25, 2022, 9:29am
7
Hi Logan,
I’m talking about the toolbar that is in the demo with pdfjs express (I’m not sure if you guys refer to that as the secondary annotation toolbar). Also it looked like Dandara’s solution was able to work for me and not the setToolBarGroup method, though i’m unsure why.
