We would like to mimic the Docusign feature of clicking a button that will automatically move focus to the next field (which can be done by hitting tab, but that doesn’t work on mobile) or to focus on the next signature or initial field.
How can we accomplish this? Is there a way to know via JS which field has focus that so we can set focus forward to the next input field?
Some event, method, or css class we can hook to in order to find fields and fields types, and the ability to set focus on that field from JS
