shravan
1
How to add signature fields to PDF document ? Is there a widget in the insert section to select and add the field ?
kkim
3
You can add signature fields programatically via the following:
const instance = window.WebViewer.getInstance()
const { UI, Core } = instance;
const { documentViewer, Annotations, annotationManager, } = Core
const WidgetFlags = Annotations.WidgetFlags
// set flags for required
const flags = new WidgetFlags();
flags.set('Required', true);
// create a form field
const field = new Annotations.Forms.Field("some signature field name", {
type: 'Sig',
flags,
// create a widget annotation
const widgetAnnot = new Annotations.SignatureWidgetAnnotation(field, {
appearance: '_DEFAULT',
appearances: {
_DEFAULT: {
Normal: {
offset: {
x: 100,
y: 100,
// set position and size
widgetAnnot.PageNumber = 1;
widgetAnnot.X = 100;
widgetAnnot.Y = 100;
widgetAnnot.Width = 50;
widgetAnnot.Height = 20;
//add the form field and widget annotation
annotationManager.getFieldManager().addField(field);
annotationManager.addAnnotation(widgetAnnot);
annotationManager.drawAnnotationsFromList([widgetAnnot]);
shravan
5
Thanks Kevin
This adds it a random position on the page. How do I create the field where I intend to place it?
kkim
6
You could use the mouseLeftUp event from the documentViewer as an example and then apply the above code using the mouse coordinates from getPDFCoordinatesFromMouseEvent to place the signature field there:
https://pdfjs.express/api/Core.DocumentViewer.html#event:mouseLeftUp
https://pdfjs.express/api/Core.DocumentViewer.html#getPDFCoordinatesFromMouseEvent
