Which product are you using? PDF.js Express Plus
PDF.js Express Version 8.7.0
Detailed description of issue Can you provide a code sample to get the id of the currently selected annotation? I want to pass this to an external modal via querystring to bind the id of the annotation with an id from our own system.
Modal in action with our system id displayed.
Thanks for reaching out to pdf.js express forums,
You can find the properties for an annotation here: https://pdfjs.express/api/Core.Annotations.Annotation.html
const documentViewer = instance.Core.documentViewer; const annotationManager = documentViewer.getAnnotationManager(); const selectedAnnotation = annotationManager.getSelectedAnnotations()[0] selectedAnnotation.Id
Best regards, Kevin Kim
Hi Kevin, yes that was it thanks.
Best regards.
