PDF Express Js
8.X.X
on left click of mouse is it possible to highlightToolbutton option to be triggered.
on left click of mouse is it possible to triggered the highlightToolbutton menu, and capture the highlighted text.
Yes
annotationManager.addEventListener(‘annotationSelected’, (annotations, action) => {
if (action === ‘selected’) {
console.log(‘annotation selection action’, action);
const selectedAnnots = annotationManager.getSelectedAnnotations();
console.log(‘selected Content’, selectedAnnots);
} else if (action === 'deselected') {
console.log('annotation deselection', annotations);
if (annotations === null && action === 'deselected') {
console.log('all annotations deselected');
Guides:
APIs:
Forums:
May 12, 2022, 3:55pm
4
I am a bit confused by your question. Can you please be a bit more descriptive? Which menu/option do you want to trigger? What is the use case?
For example am having text paragraph consist of 10 lines, i need to select 2 lines out of 10, on left click of mouse , while selecting 2 lines i need to trigger highlightToolbutton menu function.
May 18, 2022, 4:18pm
6
There is no good way to select the highlight tool when text is selected. However, you can edit the text select tool to highlight text which is pretty close to what you want I think. here’s some code:
const { Tools } = instance.Core
const textHighlight = new Tools.TextHighlightCreateTool(instance.Core.documentViewer);
const textSelectDown = Tools.TextSelectTool.prototype.mouseLeftDown;
Tools.TextSelectTool.prototype.mouseLeftDown = function() {
textHighlight.mouseLeftDown(arguments[0])
textSelectDown.apply(this, arguments);
const textSelectMove = Tools.TextSelectTool.prototype.mouseMove;
Tools.TextSelectTool.prototype.mouseMove = function() {
textHighlight.mouseMove(arguments[0])
textSelectMove.apply(this, arguments);
const textSelectUp = Tools.TextSelectTool.prototype.mouseLeftUp;
Tools.TextSelectTool.prototype.mouseLeftUp = function() {
textHighlight.mouseLeftUp(arguments[0])
textSelectUp.apply(this, arguments);
Hi Logan,
Excellent it worked for me, highlightToolbutton is triggering when i select.
is it possible to capture highlighted text in some variable?
May 20, 2022, 2:29pm
8
Hey!
In the mouseLeftUp event you could call documentViewer.getSelectedText() like so:
const text = instance.Core.documentViewer.getSelectedText()
console.log(text)
