How to add/update/delete annotations based on condition?
PDF.js Express
When the event “annotationChanged” will call, I want to add/update/delete annotations based on conditions otherwise not. But now it always add/update/delete annotations even after I added my conditions.
After checking my condition. No annotation should be added/updated/deleted.
Issue happens with every document
annotationManager.addEventListener('annotationChanged', (annotations, action, { imported }) => {
      if (imported) {
        return;
      } else if(myCondition){
        // do something and return.
        return;
        if (action === 'add') {
        console.log('this is a change that added annotations');
      } else if (action === 'modify') {
        console.log('this change modified annotations');
      } else if (action === 'delete') {
        console.log('there were annotations deleted');
Hi Arman,
Because the event listener is just listening to events, trying to return from this method will not have an effect on the actual actions.
If you want to disable these actions, I would recommend enabling the read only mode.
Zach Serviss
