I use a custom stamp. I also have an eventListener on ‘annotationChanged’. If I move the stamp from one page to another using drag & drop, the event listener ‘annotationChanged’ is triggered once with the action ‘delete’, once with the action ‘add’ and twice with the action ‘modify’.
Also, in the case of the ‘delete’ action, for example, the property IsDeleted is not set to true. The same applies to IsAdded and IsModified for the other two actions.
When the stamp is moved to another page, only the ‘modify’ action is triggered and the IsModified is set to true.
every
annotationChanged documentation
annotationManager.addEventListener(‘annotationChanged’, (annotations, action, { source }) => {
console.log(‘annotationChanged’, action, source)
if (action == ‘add’) {
annotations.forEach((annotation) => {
console.log(‘add’, annotation.IsAdded, annotation)
if (action == ‘modify’) {
console.log(‘modify’, annotation.Id, annotation.IsModified, annotation)
if (action == ‘delete’) {
console.log(‘delete’, annotation.Id, annotation.IsDeleted, annotation)
// const { signatureId, id } = this.extractDataFromAnnotation(annotation)
// this.api.destroy(signatureId, id)
