How to annotate text when receiving text as a string in pdf?
We are getting text as a string from backend and we need to search that in our pdf and highlight it with a red box. Is that possible with pdf js express?
HIghlighting text with red box on receiving array with text string from backend.
instance.searchText() lets you search for strings and automatically highlights the results for you.
You can also change the color of the highlights (see code below).
WebViewer(...).then(instance => {
   const {docViewer} = instance;
       docViewer.setSearchHighlightColors({
         searchResult: new Annotations.Color(0, 0, 255, 0.5),
         activeSearchResult: 'rgba(0, 255, 0, 0.5)'
       instance.searchText('your text here')
We do have other more advanced search APIs if you need more flexibility, so if this solution doesn’t work for you let me know and I can help you out with those.
Hi Logan,
Thanks for the solution. Is there any way to create a outline box around the searched word instead of a highlight color?
This gets into the more complex APIs that I was talking about. Here is a code sample doing what you want:
  const { annotManager, Annotations, Tools, docViewer, CoreControls } = instance;
    const mode = CoreControls.Search.Mode.PAGE_STOP | CoreControls.Search.Mode.HIGHLIGHT;
    const searchOptions = {
      // If true, a search of the entire document will be performed. Otherwise, a single search will be performed.
      fullSearch: true,
      // The callback function that is called when the search returns a result.
      onResult: result => {
        // with 'PAGE_STOP' mode, the callback is invoked after each page has been searched.
        if (result.resultCode === CoreControls.Search.ResultCode.FOUND) {
          const textQuad = result.quads[0].getPoints(); // getPoints will return Quad objects
          console.log(textQuad);
          const annot = new Annotations.RectangleAnnotation();
          annot.StrokeColor = new Annotations.Color(255, 0, 0, 1);
          annot.X = textQuad.x1;
          annot.Y = textQuad.y3;
          annot.Width = textQuad.x2 - textQuad.x1
          annot.Height = textQuad.y1 - textQuad.y3
          annotManager.addAnnotation(annot)
          annotManager.redrawAnnotation(annot)
    docViewer.textSearchInit('YOUR_TEXT', mode, searchOptions);
API references can be found here.
Thanks Logan . This was really helpful!
