How to disable widgets and links using exportAnnotCommand
I’m trying to remove the links and widgets from the xfdfString when I call exportAnnotCommand(), I see there is a way to do this in exportAnnotations(), however I cannot use this one because I am building a realtime collaboration page. Is it possible in version 8?
Only provide the add/modify/delete in the xml string for the specific annotation, not links.
annotManager.exportAnnotCommand().then(xfdfString => {
            fetch('url-to-database', {
              method: 'POST',
              headers: {
                'Content-Type': 'application/urlformencoded',
              body: xfdfString
We do not have a dedicated API for this currently, however there is a “hack” to work around it.
exportAnnotCommand only exports annotations that have changed, so we can set the annotations you don’t want exported to “not changed” state.
To do this, call this code right before you call exportAnnotCommand
const fieldManager = annotManager.getFieldManager()
fieldManager.getFields().forEach(field => field.IsModified = false)
I hope this helps!
Great thanks Logan I will give this a try!
