How to fill color and opacity to rectangle annotation tool?
Need to provide a green fill color with opacity 0.3 to the annotated part of pdf.
You can apply a opacity directly to the annotation if you are creating it programmatically.
const annot = new Annotations.RectangleAnnotation();
annot.Opacity = 0.3;
You could also use the setStyles API to set the default color of rectangles. You can read a guide about it here.
If neither of these work for you, please let me know and provide some more details about how you’re actually creating the annotation.
