PDF.js Express Version*
8
i have Annotate button on my PDF.js viewer, now whether i click or not i am able to draw the rectangle box for area i want to add annotation. so in my requirement, except rectangular red tool, we shouldnt use any, accordingly i have handled, so only rectangle tool is available.
After click on that button only, user must be able to draw rectangular annotation
yes
path: '../../wv-resources/lib',
this.viewer.nativeElement
).then((instance: any) => {
const { documentViewer, annotationManager, Annotations } = instance.Core;
this.hidingButtons(instance, documentViewer, Annotations);
// bind pdf based on api hit with base64ToBlob format
instance.UI.loadDocument(this.base64ToBlob(doc), { filename: 'myfile.pdf' });
// setting title to userRole instead of Guest
instance.Core.annotationManager.setCurrentUser(this.role);
// Rectangular Annotation
instance.UI.setToolMode(instance.Core.Tools.ToolNames.RECTANGLE);
if (instance.UI.getToolMode().name === 'AnnotationCreateRectangle') {
instance.UI.disableElements(['annotationStyleEditButton']);
hidingButtons(instance: any, documentViewer: any, Annotations: any) {
instance.UI.setHeaderItems(function (header: any) {
const toolsOverlay = header.getHeader('toolbarGroup-Annotate').get('toolsOverlay');
'toggleNotesButton',
'toolbarGroup-Shapes',
'toolbarGroup-Edit',
'toolbarGroup-Insert',
'toolsHeader',
'toolbarGroup-View',
'toolbarGroup-FillAndSign',
'annotationCommentButton',
'annotationStyleEditButton',
'annotationDeleteButton',
'annotationCropButton',
'annotationRedactButton',
'annotationGroupButton',
'annotationUngroupButton',
'calibrateButton',
'linkButton',
'fileAttachmentDownload',
'panToolButton',
'colorPickerColors',
'stylePopup',
'textPopup',
'contextMenuPopup',
'ColorPickerModal',
'selectToolButton',
'highlightToolButton2',
'highlightToolButton3',
'highlightToolButton4',
'searchButton',
'textStrikeoutToolButton',
'textHighlightToolButton',
'textSquigglyToolButton',
'leftPanelButton',
'menuButton',
'viewControlsButton',
'highlightToolButton',
'rectangleToolButton',
'rectangleToolButton4',
'rectangleToolButton3',
'rectangleToolButton2',
'underlineToolButton',
'underlineToolButton2',
'underlineToolButton3',
'underlineToolButton4',
'strikeoutToolButton',
'strikeoutToolButton2',
'strikeoutToolButton3',
'strikeoutToolButton4',
'squigglyToolButton',
'squigglyToolButton2',
'squigglyToolButton3',
'squigglyToolButton4',
'stickyToolButton',
'stickyToolButton2',
'stickyToolButton3',
'stickyToolButton4',
'stickyToolButton',
'freeTextToolButton',
'freeTextToolButton2',
'freeTextToolButton3',
'freeTextToolButton4',
'freeHandToolButton',
'freeHandToolButton2',
'freeHandToolButton3',
'freeHandToolButton4',
instance.UI.disableFeatures([instance.UI.Feature.Print]);
// disable text selection
instance.UI.disableFeatures([instance.UI.Feature.TextSelection]);
