Turn annotations off in plus?
Express - latest version
I’m adding pdf.jsexpress plus to my product, but I want to release it without annotations first.
Currently I’m hiding the ribbons, and the toggle notes button… But I just realized right click also shows the annotation tools in the context menu popup.
Is there a way to simply disable annotations, or do I need to manually delete the items from the context menu popup too?
Hi Elliot,
Probably the easiest way to achieve this is to turn on setReadOnly(true) to disable all annotations.
https://pdfjs.express/api/Core.AnnotationManager.html#setReadOnly__anchor
Zach Serviss
Perfect, this is exactly what I wanted - thank you!
