I want measure a length of curved line using Perimeter Measurement, but I dont know how to do it
Is there any way to measure curved line ?
system
#3
Guides:
APIs:
Forums:
Hi there!
I recommend that you upgrade your version of Express to version 8.6 as there is an Arc Measure tool that will be useful in these situations.
Here is the documentation for the tool:
https://pdfjs.express/api/Core.Tools.ArcMeasurementCreateTool.html
Zach Serviss
www.pdftron.com
