I have stuck with some changes which I am interested to change.
Guide me to these following changes:
Distance (
AnnotationCreateDistanceMeasurement) measurement tool while drawing should not show that real-time measurement like (10.5 sq. m.) over the double end arrowed line. It should be same as perimeter line. EXPECTED -Over the line, that meausurement should be removed/hidden. -
Sometimes on zoom in, plan doesn’t get clear. It remains blur. Then after again zoom out and zoom in, then it gets clear/visible to read text in the pdf. Don’t understand what’s the issue in rendering the pdf.
Sometimes, it fails to load document and gets stuck with the loading. Happens for large & small single page pdf too. (Used -
loadDocument())
