How to move rubber stamp out of mis tool and remove another group annotation
{I want to move the rubber stamp group out of the mis tools, and place it on the header to eliminate action click from user,
{when i use header.delete(indexNo) base on the console index, look like the order is not corrected. For example when i use header.delete(13), it will delete signature group, but the index(13) show in the console is shapeTools
{Yes}
{header.delete(13)}
This code moves the rubber stamp into the main header:
  // remove old toold
  instance.updateTool('AnnotationCreateRubberStamp', { buttonGroup: '' });
  // add new tool
  instance.setHeaderItems(header => {
    const items = header.getItems()
    header.get('freeHandToolGroupButton').insertBefore({
      type: 'toolButton',
      toolName: 'AnnotationCreateRubberStamp'
    header.update(items);
Thank you, i will try
