- Core version: “8.1.1”
- Full API: false
- UI version: “8.1.0”
- WebViewer Server: false
I’am using Free Pdf Express Viewer with pure Javascript/HTML.
How to remove divider from header?
Guides:APIs:Forums:Hey!
You can use the setHeaderItems api to filter out thing in the header you do not want:
This will remove all dividers in the header:
instance.UI.setHeaderItems(header => {
const items = header.getItems().filter(item => item.type !== 'divider');
header.update(items);
If you want to just remove a specific one, you can just remove it from the array returned by getItems.
