UI Version: 8.4.1
Core Version: 8.4.0
Header is too small on mobile
Header Bar should be bigger on mobile like on desktop.
This issue happen in every document on mobile
I’m currently using the default document: https://pdftron.s3.amazonaws.com/downloads/pl/webviewer-demo.pdf
path: './node_modules/@pdftron/pdfjs-express-viewer/public',
licenseKey: 'xxxx',
initialDoc: 'https://pdftron.s3.amazonaws.com/downloads/pl/webviewer-demo.pdf',
.then(instance => {
instance.UI.setHeaderItems(function (header) {
const items = header.getItems()
//remove element from items array
items.splice(0, 3)
header.update(items);
Andrea
