tomc
March 11, 2025, 5:39pm
1
UI Version = 8.7.0
Core version = 8.7.5
I’m receiving the following error when trying to import signatures after exporting them. I see these errors in the console.
I’d expect to see the signature in the dropdown
All documents
N/A
const signatureTool = instance.Core.documentViewer.getTool('AnnotationCreateSignature');
let _signatures;
signatureTool.exportSignatures().then((exportedSignatures) => {
if (exportedSignatures === null || exportedSignatures === undefined) {
writeErrorMessage('Signatures JSON is null or undefined');
return;
_signatures = exportedSignatures;
function populateSignatures() {
signatureTool.importSignatures(_signatures).then(() => { });
kkim
March 11, 2025, 6:59pm
3
Can you share what you are passing to the importSignatures API? Are you using a JSON?
best regards,
Kevin
tomc
March 12, 2025, 8:39am
4
I’m passing the result from the signatureTool.exportSignatures function that is being saved to a variable. I believe I’m getting an array.
kkim
March 12, 2025, 3:15pm
5
Can you try the suggested solution provided here as an example to use the importSignature API:
I have tested this issue with the following code. Could you try modifying it to match your signature, Ali?
const signatures = [
{ x: 10, y: 10 },
{ x: 50, y: 50 },
const latestAddedSignatureIndex = signatures.length - 1;
const canvas = document.createElement('canvas');
canvas.width = 500;
canvas.height = 500;
const ctx = canvas.getContext('2d');
ctx.lineWidth = 4;
ctx.strokeStyle = 'black';
ctx.beginPath();
const signatureArray = signatures[latestAddedSignat…
best regards,
Kevin
