Signature annotation not showing correctly after digitaly signed
(index) Value
UI version ‘8.1.0’
Core version ‘8.1.1’
Build ‘MTAvMjEvMjAyMXw2OGY2MTQ1NWU=’
WebViewer Server false
Full API false
I have a digitally signed a pdf document with the library, however when I try
to add additional signer it shows the previous signature as “Sign Here”
The editor should show the signature image just as I open it as in Adobe Acrobat Reader
including a screenshot below:
loadViewer(file) {
      path: '../../../../assets/static/lib',
    }, this.viewer.nativeElement)
    .then(async instance => {
      const {  Annotations, annotationManager, documentViewer } = instance.Core;
      this.wvInstance = instance;
      instance.UI.loadDocument(file, { filename: file.name });
      documentViewer.addEventListener('annotationsLoaded', () => {
        const signatureWidgetAnnots = annotationManager.getAnnotationsList().filter(
          annot => annot instanceof Annotations.SignatureWidgetAnnotation
      signatureWidgetAnnots.forEach((annot) => {
        annot.isSignedInitially().then((isSigned) => {
          if (isSigned) {
            console.log('is signed')
            // if this signature field is not signed initially
      annotationManager.addEventListener('annotationChanged', (annots, action) => {
        const document = documentViewer.getDocument();
        if (action === 'add') {
          for (const annot of annots) {
            if (annot.Subject === 'Signature') {
              const { X, Y, Width, Height, PageNumber } = annot;
              const { width, height } = document.getPageInfo(PageNumber)
              this.signature = this.generateAnnotationImage(annot, 1)
              this.coordinates = {
                x: X,
                y: height - Y
        if (action === 'modify') {
              const { width, height } = document.getPageInfo(PageNumber);
                x: X,
                y: height - Y
The block quote is saying that annot.isSignedInitially() is undefined
Hi There,
Thanks for your question. Part of the problem was resolved in the latest version, so I’d like to ask you to update your PDF.js Express version, please. Unfortunately, we found another issue that we need to investigate, but there is a workaround that you can use until we fix it.
The issue is, your signature will appear but the Sign Here widget will remain. Following is part of your code modified a bit to fix this problem.
loadViewer(file) {
   signatureWidgetAnnots.forEach((widget) => {
      const isSigned = !!widget.annot;
        if (isSigned) {
          annotationManager.deleteAnnotations([widget]);
Please let me know if this works for you.
Thank you,
Dandara
Thank you it works perfectly now !
Please consider to ping me here when a new fix is available so i can update the version,
All the best,
Ezan
