I have attempted integrating the xfdf output with pdfs in itext7 but without success. Do you know if xfdf output should be compatible with either Ironpdf or itext7?
Yes, the XFDF should be compatible with any other program.
Can you provide a code sample of how you are extracting the XFDF?
