Failed xfdf downloading
PDF.js Express Plus 8.x.x.
Tried to download pdf with annotations, xfdfs. It happens every document.
WebViewer(…)
.then(instance => {
const { documentViewer, annotationManager } = instance.Core;
// Add header button that will get file data on click
instance.UI.setHeaderItems(header => {
  header.push({
      type: 'actionButton',
      img: '...',
      onClick: async () => {
        const xfdfString = await annotationManager.exportAnnotations();
        const options = {
          filename: 'myDocument.pdf',
          xfdfString,
          downloadType: 'pdf'
        instance.UI.downloadPdf(options);
Would like to know how to download xfdfs.
Thanks in advance.
Heejung
Hi there!
Sorry for the delay - I was away for a few days (It was a long weekend here in Canada).
The functionality you are trying to do is not supported in PDF.js Express without the use of the rest API.
If you need to merge XFDF into a document, please see this guide.
Hi Logan,
We will try it.
Thank you!
