I want to pass mouse location manually for pasteCopiedAnnotations( [useMouseLocation]); method. Actually I want to paste annotations at a certain position where I have x and y coordinates.
Is there any way to do this instead of passing a boolean, we can set a mouse location and then it will paste there. Annotations are Area/Linear.
Manually set mouse location for pasting annotation.
instance.annotManager.pasteCopiedAnnotations([true]);
Guides:
APIs:
Forums:
Hi Kiran,
You can override hotkeys by using this API. By overriding ctrl+c and ctr+v you can control the behaviour of how you want to paste, by for example in this snippet changing the location of the annotation.
const { annotManager } = instance;
let copiedAnnots;
instance.hotkeys.off(instance.hotkeys.Keys.CTRL_C);
instance.hotkeys.off(instance.hotkeys.Keys.CTRL_V);
instance.hotkeys.off(instance.hotkeys.Keys.COMMAND_C);
instance.hotkeys.off(instance.hotkeys.Keys.COMMAND_V);
instance.hotkeys.on('ctrl+c', e => {
copiedAnnots = annotManager.getSelectedAnnotations();
instance.hotkeys.on('ctrl+v', e => {
copiedAnnots.forEach((annot) => {
const copiedAnnot = annotManager.getAnnotationCopy(annot);
// adjust paste location here
copiedAnnot.X = 50;
copiedAnnot.Y = 50;
annotManager.addAnnotation(copiedAnnot);
annotManager.redrawAnnotation(copiedAnnot);
Do note this currently only overriding window ctrl+c & ctrl+v as a proof of concept. I would recommend for a production environment to also override command+c and command+v for Apple devices.
Cheers,
Dustin
