Listen for the print event
Wanting to know if there is a way to attach an event listener onto the print method.
When a user clicks the print button I would like to be notified.
Hi Andy,
Thanks for your question.
One option would be using the UI event VISIBILITY_CHANGED. (Click here for this event documentation)
Here is a code snippet to help you
import WebViewer from '@pdftron/pdfjs-express-viewer'
...options
}).then(instance => {
  const UIEvents = instance.UI.Events;
  instance.UI.addEventListener(UIEvents.VISIBILITY_CHANGED, e => {
    const { element, isVisible } = e.detail;
    if(element === 'printModal' && isVisible) {
      console.log('The user clicked the print button and the print modal is now open');
Let me know if this works for you.
Thank you,
Dandara
Thanks Dandara, this will be helpful and I’ll give it a try.
Know of any way to track the print button after they’ve opened this modal?
Hi Andy, my pleasure.
You can add the following code to track the print button after the modal is open.
...options
    const iframeDoc = instance.UI.iframeWindow.document;
    const modalPrintButton = iframeDoc.querySelector('.PrintModal .button');
    modalPrintButton.addEventListener('click', () => {
      console.log('Print button was clicked');
Do you mean the print button inside the modal, correct?
Please let me know if this works for you.
Dandara
This worked Dandara, thanks for showing me how to access the iframe document.
:+1: :+1:
