Manually add watermark for printing
I wanted to know if there was a way to add a watermark to the pdf when it is printed. I know there is a UI available in the print menu, but just wanted to know if there was a manual process so that a user always has a watermark when they print.
Add a watermark to the pdf when it’s printed, we don’t want the watermark to appear in the viewer.
Hi Andy,
While there isn’t a specific API to handle this, you could find the print button in the HTML and add an event listener to add a watermark on click.
Something like this would work:
  const iframeDoc = instance.UI.iframeWindow.document;
  const printButton = iframeDoc.querySelector('[data-element="printButton"]');
  printButton.addEventListener('click', () => {
    console.log('clicked')
    documentViewer.setWatermark({
      // Draw diagonal watermark in middle of the document
      diagonal: {
        fontSize: 25, // or even smaller size
        fontFamily: 'sans-serif',
        color: 'red',
        opacity: 50, // from 0 to 100
        text: 'BUTTon clicked'
Zach Serviss
Thanks Zach, would this then add a watermark onto the document view as well after printing?
No it does not had the watermark to the viewer, only on the print view.
I just tested, and I can see the watermark in the document viewer after closing the print modal.
I think I just need to erase the watermark once the modal is closed. Is there a method for erasing a watermark?
Sorry Andy, I didn’t do enough testing to see that it did add the watermark to the document viewer!
Simply setting the watermark to an empty object should do the trick.
  window.addEventListener('afterprint', () => {
    documentViewer.setWatermark({});
Hey @zserviss This doesn’t seem to work for me.
Which browser are you using?
I’m using Chrome v104. The afterprint listener doesn’t appear to hook into anything.
I’ve tested it in Safari and it works there.
Maybe try an other event listener like when the print modal is closed or something else. I can confirm that setting the watermark to an empty object clears the watermark.
Okay here’s what I have done to solve this:
instance.iframeWindow.addEventListener("visibilityChanged", (event) => {
  if (event.detail.element === "printModal") {
    if (event.detail.isVisible) {
        diagonal: {
          fontSize: 55,
          color: 'red',
          opacity: 40,
          text: 'Custom watermark text'
      // Clear the watermark
Excellent! Happy to hear you were able to solve this. :smiley:
