Can’t change the document in the viewer after openning another document.
Hello here, i’m developping an app where customer can see documents they loaded before. i have a issue if i click on a random doc to see it it appears. after closing it and try to access another one the same file appears. The thing is that in my dom my variable is updated but in the viewer no.(Looked at the forum and figured out why. Since it’s a bad pratice i don’t what to reload the viewer several times to keep the performance of my app). Is it possible to update my initial doc every time i need to show up my viewer ? (I’m using Vuejs)
every document
viewPDF(
path: ‘/lib’,
initialDoc: this.currentDoc?.data,
licenseKey:xxxxxxxxxxxxxx
}, document.getElementById(‘viewer’)
).then((instance) => {
this.myInstance = instance
const { Core } = instance
      console.log('document loaded')
      'pageNumberUpdated',
      (pageNumber) => {
        console.log(`Page number is: ${pageNumber}`)
      'pagesUpdated',
      (changes) => {
        console.log(changes)
On click of each document i update my variable and call this code to show document
