Merging XFDF using the Express REST API using URL
Regarding
I have tried as per comment but annotations not showing
It looks like you are opening a different document than you started with? Here is my code that works:
  var xfdf = await annotManager.exportAnnotations({ links: false, widgets: false });
  var fileData = await docViewer.getDocument().getFileData({});
  // var blob = new Blob([fileData], {type: 'application/pdf'});
  var data = new FormData();
  data.append('xfdf', xfdf);
  data.append('file', 'http://africau.edu/images/default/sample.pdf');
  data.append('license','');
  // Process the file
  var response = await fetch('https://api.pdfjs.express/xfdf/merge', {
      method: 'post',
      body: data
  }).then(resp => resp.json());
  var { url, key, id } = response;
  // Download the file
  var mergedFileBlob = await fetch(url, {
      headers: {
          Authorization: key
  }).then(resp => resp.blob())
  instance.loadDocument(mergedFileBlob);
Dear Logan,
Please check
ezgif.com-crop
Do you have disableFlattenedAnnotations set in the constructor by chance? This would disable those annotations being drawn.
I cannot reproduce your issue. If you could send me a code sample of how you are saving/loading the document, as well as how you are loading webviewer, that would help.
This is the code i have used.
    disableFlattenedAnnotations: true,
    path: '/medc/lib',
    licenseKey: '', // optional
    initialDoc: pdf_url,
    .then(function(instance) {
        var docViewer = instance.docViewer;
        var annotManager = instance.annotManager;
        var Annotations = instance.Annotations;
        instance.setHeaderItems(function(header) {
            header.push({
                type: 'actionButton',
                img: '<svg xmlns="http://www.w3.org/2000/svg" width="24" height="24" viewBox="0 0 24 24"><path d="M0 0h24v24H0z" fill="none"/><path d="M17 3H5c-1.11 0-2 .9-2 2v14c0 1.1.89 2 2 2h14c1.1 0 2-.9 2-2V7l-4-4zm-5 16c-1.66 0-3-1.34-3-3s1.34-3 3-3 3 1.34 3 3-1.34 3-3 3zm3-10H5V5h10v4z"/></svg>',
                onClick: function() {
                    onSave();
                    async function onSave() {
                        // Process the file
                            method: 'post',
                            body: data
                            headers: {
                                Authorization: key
                     /*   var data_PDF = new FormData();
                        data_PDF.append('data' , mergedFileBlob);
                        var xhr = new XMLHttpRequest();
                        xhr.onreadystatechange = function() {
                            if (this.readyState == 4) {
                                $('#cover-spin').hide(0);
                                $("#ed-alert").css("display", "block");
                                setTimeout(function() {  $("#ed-alert").css("display", "none"); }, 5000);
                                $('#cover-spin').show(0);
                        xhr.open('POST', upload_url, true);
                        xhr.send(data_PDF);*/
                        // Do something with blob...
                        // save(mergedFileBlob)
Having disableFlattenedAnnotations: true, will disable any annotations from rendering unless you import the XFDF directly, that is why the annotations aren’t rendering.
Dear Logan,
I have tried small size pdf it is working perfect.When i try 15 MB PDF getting Internal server error.Please check given pdf url
[http://smoinoman.com/pdf/testdraw.pdf](http://Test Pdf)
Thank you!
I will try this document out and see what’s going on. This is a pretty complex document.
Hi @jithinkp, this should be fixed now! (issue was just that the request was timing out)
