Core version: “8.7.4”
UI version: “8.7.0”
Make the pageNavOverlay (showing at the bottom of the page) static i.e. always visible
UI version: “8.7.0”
Hello Retrotech,
You can keep the pageNavOverlay visible by changing the CSS properties.
Here is a guide on how to customize styles in the viewer: PDF.js Express Viewer Style Customization (Color & CSS) | Documentation
licenseKey: 'YOUR_LICENSE_KEY',
path: 'lib',
css: 'path/to/stylesheet.css'
In the CSS file, you can add the following snippet to ensure the pageNavOverlay doesn’t disappear.
.PageNavOverlay {
opacity: 1!important;
Darian
I couldn’t get it to work with the CSS path. Maybe the reference path was wrong. Instead I used the below
const iframeDoc = instance.UI.iframeWindow.document;
const querySelector = iframeDoc.querySelector('[data-element="pageNavOverlay"]');
querySelector.style.opacity = 1
querySelector.style.visibility = 'visible';
The CSS path reference is likely incorrect. If you are using a React project, I think the file will have to be in the public folder.
If your file is in ‘public/files’ then the constructor should be:
css: '/files/custom.css',
We recommend using this approach instead of the iframe way.
Darian
