We open a PDF that contains annotations that are visible in Adobe PDF, but they are not displayed using PDF.js.
I’ve tried changing disableFlattenedAnnotations, but it doesn’t work.
This is what it should display:
This is the first time that we try to open a PDF with embedded annotations.
path: ‘/static/lib’,
initialDoc: FILE_NAME,
disableFlattenedAnnotations: false,
}, element).then(instance => {
const { docViewer, annotManager, Tools, Annotations, PDFNet, CoreControls } = instance;
// Document needs to be loaded before we can import annotations
instance.docViewer.on(‘documentLoaded’, async () => {
documentStream = await instance.docViewer.getDocument().getFileData({});
documentBlob = new Blob([documentStream], { type: 'application/pdf' });
