Hello there,
I noticed you are using React 18 in your project. Could you try using React 16 instead and see if that resolves the issue?
Hello there,
Please remove the repo as there is a license key in your application.
We think this could be an issue with the routing (react-router) in the application. It looks like you will need to do further configuration. In the network tab of your production build, you can see the ui get requested but the response is incorrect.
ui in network
The response is not returning the right file, instead it is returning your application’s entry point (index.html).
It looks like you route invalid wildcard routes to the dashboard. This could explain why the dashboard appears instead of the viewer.
<Route path="*" element={<Navigate to="/dashboard" />} />
Another thing to note is that this path appears incorrect when viewing the WebViewer div. It is likely from the start_url prop in the manifest. The issue seems to get resolved for dev but not production.
You will need to configure the WebViewer lib to be served along the other static assets.
Chen
Still not able to load pdfviewer in production build of react.
What i have basic admin dashboard template of Material Dashboard 2 React: Free MUI & React Admin Template @ Creative Tim.
Router issue you pointed out is it because it is redirected to index page in case of production build
FYI ,Removed repo
NIrmal Kumar.R
Hello,
You may need to eject the app and look more into the React Router documentation.
Were you able to configure the router settings?
Could you try using HashRouter instead of BrowserRouter and see if that resolves issue?
