Requiring Signature Text to be changed
We are trying to add a way to avoid having the user be able to enter the word Guest in the typed signature.
To be able to attach to the signature-create button so we can return true or false if we approve of the signature, which will allow us to compare the text entered with what we allow.
Currently I have tried to attach it to the save event but this event is fired after the signature is created. We are looking for an even that fires before its created to approve or disapprove of the text entered.
 const sigTool = docViewer.getTool('AnnotationCreateSignature');
                    sigTool.addEventListener("signatureSaved", (annotation) => {
                        console.log(annotation);
                        console.log("Saved");
Hey Eric,
Thanks for your question about Signature Widget.
The word “Guest” in the typed signature is related to the current user name. We can make this value empty and the Create button will be disabled. Also, we can check if the user types “Guest” again and the button will be disabled as well.
Let me know if this approach works for you and if so, here is a guide code
const { annotationManager } = instance.Core;
  annotationManager.setCurrentUser('');
  const iframeDoc = instance.UI.iframeWindow.document;
  const signatureInput = iframeDoc.querySelector('.text-signature-input');
  const signatureCreateButton = iframeDoc.querySelector('[data-element="textSignaturePanel"] .signature-create');
  signatureInput.addEventListener('input', (e) => {
    let inputValue = e.target.value.trim().toLowerCase();
    if (inputValue === 'guest') {
        signatureCreateButton.disabled = true;
      signatureCreateButton.removeAttribute('disabled');
Hope this helps,
Thank you,
Dandara
