Scroll Bar not display when load document and i need to reload frame
i need to reload fram to show scroll bar
After reload frame
Thank you for reaching out to pdf.js express forums,
Are you able to reproduce this issue on our demo?
If not, could you please update to the latest version and see if you can reproduce the issue in your environment?
If issue persists, could you please share the PDF to reproduce the issue?
Hi kkim, the issue only occurs when i put the viewer frame in vuejs component, i think this isssue relate to config css
Please take a look at our vue sample for additional guidance:
