Setting initial page
Is there a way to set initial page number when opening a document?
I want to save last viewed page number and next time when opening the same document, it should start from that page.
Yes
Below is the code of useEffect() hook in one of my Next.js components:
useEffect(() => {
      import("@pdftron/pdfjs-express-viewer").then(() => {
            path: "/webviewer/lib",
            licenseKey: process.env.NEXT_PUBLIC_PDFJS_KEY,
          viewer.current
        ).then((inst: any) => {
          instance.current = inst;
          // Set the document
          const blob = new Blob([bookBuffer], {
            type: "application/octet-stream",
          inst.UI.loadDocument(blob);
          // Set the language
          inst.UI.setLanguage(language);
          // Disable elements
          const elements = [
            "downloadButton",
            "printButton",
            "languageButton",
            "coverLayoutButton",
            "contextMenuPopup",
          if (contentIsScanned) {
            elements.push("searchButton");
          inst.UI.disableElements(elements);
          // Get page number
          const { documentViewer } = inst.Core;
          documentViewer.addEventListener('pageNumberUpdated', (pageNumber: number) => {
            currentPage = pageNumber;
            console.log("PAGE NUMBER", pageNumber)
  }, [bookId]);
Thank you for reaching out to pdf.js express forums,
One way could be to save the page number (i.e. database) as you have in the above code, then use that page number to set the current document page on documentLoad:
https://pdfjs.express/api/Core.DocumentViewer.html#setCurrentPage
Wow, it worked.
I’ve been calling setCurrentPage() on the inst instead of documentViewer.
Anyways, I appreciate your help, thanks a lot!
