Signature Fields
Hello!
About PDF.js Express Signature Field | Documentation
Can we have 2 types of signatures fields on the same document?
One for signatures and one for initials for example.
{Description here}
Right now we only support standard signature fields (this is part of the PDF spec). If you wanted the user to do an initial instead of a signature you would have to enforce that on your end.
I think you might find this guide useful (this is a WebViewer guide but it applies to PDF.js Express as well). What you could do is change the style of your initial fields to say “Add initials here” or something.
@Logan,
I first put StampAnnotations (with different styles for initials and signature) so the user can choose the locations in the document.
Then I change these StampAnnotations to SignatureWidgetAnnotation, but I can’t create different styles for the signature widgets. When I change to what would be the initials, it also changes to what would be the signature.
That is, I cannot make a SignatureWidgetAnnotation with “Sign here” and another with “Initial here” in the same document.
How could I do this?
Hey!
When you create the SignatureWidgetAnnotation, you could insert some custom data on the annotation which you can use to identify which styling the element should have:
    const annot = new Annotations.SignatureWidgetAnnotation(field, {});
    annot.setCustomData("type", "initial"); // set the type of signature here
    const createSignHereElement = Annotations.SignatureWidgetAnnotation.prototype.createSignHereElement;
    Annotations.SignatureWidgetAnnotation.prototype.createSignHereElement = function () {
      // signHereElement is the default one with dark blue background
      const signHereElement = createSignHereElement.apply(this, arguments);
      const type = this.getCustomData("type");
      if (type === "initial") {
        // set initial theme here
        // set signature theme here
      return signHereElement;
Hi, @Logan!
I’ve tried something like this and it didn’t work.
But it was because I put the SignatureWidgetAnnotation prototype while creating the document and then exporting the xfdf. When I imported the xfdf into another WebViewer, the prototype reverted to the default (white text and blue background).
So I just put the custom SignatureWidgetAnnotation prototype when I want to use the widgets to sign.
Thanks for your help!
And I didn’t use customData either. :sweat_smile:
Glad you figured it out!
Let me know if there’s anything else you need help with
