It is set for the PDF to be on ‘Cover Facing Page,’ but there is a small gap between the pages. Can they be merged? Because there is the same text on the PDF that goes from one page to another, it should be merged for easier reading.
All documents
Hey djordje.krstic97,
You can use:
instance.Core.documentViewer.setMargin(// margin)
When I use instance.Core.documentViewer.setMargin(), the fit page is disturbed and NaN value is printed, making it impossible to view the file. Therefore, I have to click on a value, such as 100%, in order for the PDF file to appear. Why isn’t fit page working?
Please pass in a value to set the margin as (in pixels)
https://docs.apryse.com/api/web/Core.DocumentViewer.html#setMargin
