UI.setLayoutMode(Continuous) doesn't work
Version 8.7.0
I want to have all pages to be visible, one under the other.
I tried it with UI.setLayoutMode(UI.LayoutMode.Continuous) but it doesn’t work.
The pdf container has an appropiate size for all pages.
Pls check attached simple example. What I am doing wrong ?
<html>
<head>
    <title>feature test</title>
    <script>
        function init() {
                    path: './lib', // path to the PDF.js Express'lib' folder on your server
                    licenseKey: 'erYOL5fTH6Qt7nvCTnmQ',
                    initialDoc: './test.pdf'
                }, document.getElementById('pdfcont')
            ).then(instance => {
                const {Core, UI} = instance;
                UI.setFitMode(UI.FitMode.FitPage);
                UI.setLayoutMode(UI.LayoutMode.Continuous);
    </script>
</head>
<body onload="init()">
<div id="pdfcont" style="width:600px;height:1500px;background-color: aliceblue"></div>
<script src="lib/webviewer.min.js"></script>
</body>
</html>
Hello thomas.damer,
I was able to get this working on our demo site: PDF.js Viewer Demo | PDF.js Express
Can you elaborate more on “it doesn’t work”? any errors, unexpected behaviour, etc.
Many Thx for the fast response. I tried it with Chrome and Edge and it works. Seems to be an issue with firefox.
Pls check console output.
Firefox Developer Edition 115.0b9 (64-Bit)
console.table() logDebugInfo.js:44:14
(Position)	Wert
UI version	8.7.0
Core version	8.7.0
webviewer.min.js	8.7.0
Build	Ny8yMC8yMDIyfDJhMWM5ZWYwOA==
WebViewer Server	false
Full API	false
'setCustomModal' deprecated since version 8.5. Please use UI.addCustomModal instead addCustomModal.js:98:10
**Warning: TT: undefined function: 3**
Hello thomas.damer,
I tried on the samples page here: PDF.js Viewer Demo | PDF.js Express with Firefox, and the APIs worked as expected.
Could you post a step by step guide, or a minimal sample to reproduce?
Thank you,
