Two instances of WebViewer were created on the same HTML element. Please create a new element for each instance of WebViewer
{Two instances of WebViewer were created on the same HTML element. I want only one instance.}
{Only one instance of a webviewer should render}
{Every pdf}
WebViewerModal.zip (132 Bytes)
{Attached a filet}
Hi nikhilhill19,
The zip file provided results in an empty JavaScript file.
However, there is a common scenario why this may happen, if you’re running a React application with Strict mode, the app technically renders each component twice. This isn’t a concern when you build your application, only when you’re developing, however, you can disable that. (If this is the case you’re seeing)
