On loading pdf js express viewer element we are getting an error.
@ViewChild(‘viewer’, { static: true }) viewer: ElementRef;
disableFlattenedAnnotations: true,
path: ‘…/…/wv-resources/lib’,
config: ‘…/…/wv-resources/lib/ui/config/file.js’, // relative to your HTML file
disabledElements: [
‘selectToolButton’, ‘toolbarGroup-Edit’, ‘toolsHeader’, ‘searchButton’, ‘header’,
‘panToolButton’, ‘toggleNotesButton’, ‘notesPanel’, ‘menuButton’, ‘highlightToolGroupButton’, ‘underlineToolGroupButton’, ‘strikeoutToolGroupButton’, ‘stickyToolGroupButton’, ‘freeHandToolGroupButton’,
‘toolsOverlay’, ‘viewControlsButton’, ‘leftPanelButton’, ‘toolbarGroup-Insert’, ‘toolbarGroup-Shapes’, ‘squigglyToolGroupButton’, ‘freeTextToolGroupButton’,
initialDoc: ‘assets/schedules-pdf/sample_01.pdf’
}, this.viewer.nativeElement).then(instance => {
const utils = new ExpressUtils();
const { Annotations, Tools, annotManager, docViewer } = instance;
// set pdf to full width of viewer
instance.setFitMode(instance.FitMode.FitWidth);
