Uncaught TypeError: Cannot read properties of undefined (reading 'querySelector')
When a document loads, the viewer throws a undefined error. This also happens when the mouse moves anywhere on the page. Document loads fine, but lags to render when scrolling down or back up.
I recently changed from @pdftron/pdfjs-express to @pdftron/pdfjs-express-viewer. I deleted all the previous files from pdfjs-express.
I am using blazor to develop.
Every document
WebViewer_ = await WebViewer({
path: ‘pdfjsexpress/7.8.0’,
licenseKey: key
}, viewerElement).then(instance => {
        window.getBlob(request_options,  (blob, filename) => {
            try {
                instance.UI.loadDocument(blob, { filename: filename });
            catch (e) {
                console.log(e)
Found temp solution: PDF Viewer React sample has error - #3 by dfelix
Hello rbramasco,
The fix will be fixed in our next version which should be this month. Thank you for your patience!
PDFTron
Is there any news on this error? I tested this on 8.4 as well, same issue
Hello rbramasco,
I was unable to reproduce this error on our latest version.
PDFTron
