Uncaught TypeError: object is not iterable, when loading annotation
Express Plus
I’m getting an error in the console, but things seem to work fine…
I’m loading an annotations with this code:
const [annotation] = annotationManager.importAnnotCommand(annotationData.xfdf);
annotation.authorId = annotationData.authorId;
annotationManager.redrawAnnotation(annotation);
instance.fireEvent('updateAnnotationPermission', [annotation]);
It seems to be working just fine - the annotations are loaded into the PDF, and appear correctly.
However, in the developer console, I see this message:
Uncaught TypeError: object is not iterable (cannot read property Symbol(Symbol.iterator))
Pointing to this line:
I grabbed this code from this guide #7.3, Client Setup for Collaborating with PDF.js Express | Documentation
What is causing this console error, even though it doesn’t seem like anything is broken?
Hello elliot,
I suggest using the updated syntax:
const [annotation] = await annotationManager.importAnnotations(annotationData.xfdf);
await annotationManager.redrawAnnotation(annotation);
PDFTron
Hi @tgordon ,
Thanks for getting back to me.
Even though I’m definitely on 8.7:
The code you sent doesn’t work for me, the annotations don’t load, and it fails when I try to set authorId - saying annotation is undefined.
If I add the await statements to my original code, it does get ride of the “object is not iterable” message, but then I get this message:
I should say, I’m loading a custom config, I’m not sure if that makes a difference.
Hi Elliot,
fireEvent is not an available API, however trigger is which would be used like
instance.Core.annotationManager.trigger('updateAnnotationPermission');
The await is necessary as the importAnnotations function is async
PDFTron
