Error when loading xfdf annotations
PDF.js Express
Receiving the following error when trying to load annotations using the annotationManager.importAnnotations function:
Uncaught (in promise) TypeError: fa.getElementsByTagName is not a function
at x.P_ (webviewer-core.min.js:2413:431)
at x.WW (webviewer-core.min.js:2416:203)
at webviewer-core.min.js:419:260
at new Promise ()
at qa.FQ (webviewer-core.min.js:419:197)
at a. (view-document.php?did=175&mid=97 &id=243&hide=true:597:43)
at webviewer-core.min.js:609:402
at Array.forEach ()
at a.h.trigger (webviewer-core.min.js:609:338)
at a.Ha.JQ (webviewer-core.min.js:296:191)
Annotations to be loaded successfully on the PDF
All documents
Using a local document to test
docViewer.addEventListener(‘documentLoaded’, async () => {
annotationManager.importAnnotations(loadXfdfString(userId, documentId));
const loadXfdfString = function(userId, documentId) {
return new Promise(function(resolve) {
fetch(../core/annotations-load.php?userId=${userId}&documentId=${documentId}, {
method: ‘GET’
}).then(function(res) {
if (res.status === 200) {
res.text().then(function(xfdfString) {
resolve(xfdfString);
} else{
alert(‘Failed to load the XFDF file…’);
Thanks I managed to resolve the issue by changing the import code to:
          let result = await loadXfdfString(userId, documentId);
          await annotationManager.importAnnotations(result);
