I was trying out pdfjs express specially for its form mode and tried to get details of all the fields of this pdf file but while using forEachField I am getting everything as empty. Also when I consoled the field I got a response but it did not specify all the fields, I will include the screenshot of the response.
I also tried using the same function on one of your demo pdf and it seems to work but not on the pdf that I have added the link for.
CODE 1->
path: '/webviewer/lib',
initialDoc: '/files/f8879.pdf',
viewer.current,
).then(instance => {
const { docViewer, annotManager } = instance;
docViewer.getAnnotationsLoadedPromise().then(() => {
var stack = [];
const fieldManager = annotManager.getFieldManager();
fieldManager.forEachField(function(field) {
stack.push(field); // Push root fields
console.log(field)
while (stack.length > 0) {
var current = stack.pop();
if (current.isTerminal()) {
// Work with terminal/leaf fields
else {
// Traverse children
stack = stack.concat(current.children);
CODE 2 →
viewer.current,
const { docViewer, annotManager, fieldManager } = instance;
// iterate over fields
fieldManager.forEachField(field => {
console.log(field.getValue());
field.setValue('new value');
