Viewer : Portfolios can be visualized?
It try the demo of pdfjs express : PDF.js Viewer Demo | PDF.js Express
But I can’t manage to visualize portfolios https://helpx.adobe.com/acrobat/using/overview-pdf-portfolios.html, I can visualize the main document, but not attached documents.
Is it possible ? how ?
Thank’s
Hello Sylvain,
PDF.js Express does not support the ability to work with PDF Portfolios. You could consider using our WebViewer product which does support this functionality.
Here is a list of other features WebViewer has to offer.
Darian
