Hi i updated license key in the code and upload new build on server but watermark not remove.
link = Frontend
Hi malkeet.seefat,
Do you have the license key correctly placed inside the WebViewer Constructor?
Was it working before the new build?
I also see an error in the console, so there might be something going on with your constructor
import {AfterViewInit, Component, ElementRef, OnInit, ViewChild,} from ‘-angular/core’;
import WebViewer from ‘-pdftron/pdfjs-express’;
-Component({
selector: ‘app-root’,
templateUrl: ‘./app.component.html’,
styleUrls: [‘./app.component.css’]
export class AppComponent implements OnInit, AfterViewInit {
-ViewChild(‘viewer’) viewer: ElementRef;
ngOnInit(): void { }
ngAfterViewInit(): void {
licenseKey: “j8xvB4tENiFdfjmzLWlr”,
path: ‘lib’,
initialDoc: ‘/assets/file-sample.pdf’
}, this.viewer.nativeElement)
.then(instance => {
const watermarkOptions = {
header: {
fontSize: 15,
color: ‘blue’,
center: ‘center watermark’,
diagonal: {
fontSize: 30,
fontFamily: ‘sans-serif’,
color: ‘red’,
opacity: 100,
text: ‘Watermark’
const promise = new Promise(resolve => {
// some asynchronous operations to generate the watermark options object
resolve(watermarkOptions);
documentViewer.setWatermark(promise);
documentViewer.getWatermark().then(() => {
documentViewer.refreshAll();
documentViewer.updateView();
console.log('Malkeet '+documentViewer);
this is my code
Hi malkeet.seefat,
I took a look at your version and it seems you’re using an older version of pdf.js express, which means you are using new references when they are not yet defined: Migrating to PDF.js Express 8.0 | Documentation
which explains the documentViewer error in the console.
Could you try either updating pdf.js to the newest version or changing your reference to the older namespaces and retry and let us know your results?
Can you send latest code
You can find the latest version in our download link here:
And depending on whether you are using
Express Viewer:
or Express Plus:
