Watermark showing with valid license key
PDFJS Express
We have valid key and it was working before, recently we noticed PDF JS express watermark is showing on document.
Pdf express Watermark is showing on the PDF
Default waterrnark should not show
Yes for all documents
Hi Team,
This is happening in production, and we need to resolve it as soon as possible. Please provide the solution.
Below are the PDF JS versions which we use in Angualar 18
"@pdftron/pdfjs-express": "^8.7.0",
"@pdftron/webviewer": "^8.0.0",
When going on the site, I do not see a watermark on the document loaded:
In addition, you will want to use either pdfjs express package or the WebViewer package. You cannot use both without encountering issues.
If you have a WebViewer license, I recommend migrating your pdf.js express to WebViewer:
Kevin
