WebViewer not getting loaded in IE 11
Hello Logan,
WebViewer is not getting loaded in the IE-11, I have changed my code and make it ECMA-5 supportive due to IE-11 limitations.
Please note: I am not getting any Error in the browser console.
I am using WebViewer V7.1, and I also tried with V6.3 and V5.2, to check the IE compatibility.
PFA of my entire WebViewer code and advice
Warm Regards
Webviewer_IE.zip (1.7 KB)
I am able to run PDF.js Express in ie11 just fine.
The issue is most likely coming from your code somewhere, or your build system isn’t transpiling for ie11 correctly.
IE11 doesn’t display error messages in the console unless you load the page with the console open, so make sure you are doing that to see the error messages.
Hi Logan,
I am already running the IE page with console open, however my WebViewer is not getting open in IE only.
PFA of WebViewer executed perfectly on the Chrome whereas not on IE
Warm Regards,
And moreover, You can see in the IE console that no errors are coming from my code.
Warm Regards
So the issue is that the document is not getting loaded, not that WebViewer isn’t getting loaded (I can clearly see that WebViewer is loaded in the IE11 screeshot). Please make sure to be more specific in your issues!
We do thoroughly test PDF.js Express in IE11 before every major release, so I am quite confident that everything should work as expected. Can you make sure that your code is reaching your loadDocument call? I see that you are loading a Blob from S3, can you make sure that all that code is getting run properly?
I will check surely again, Meanwhile can you please confirm the code that I shared in .zip earlier, has been fully supported in IE, or else any changes required by keeping the ECMA script in mind or in case of any other changes needed?
That kind of support will be really appreciated.
Warm Regards
Hi Logan,
Will the webviewer works for Safari too?
Warm Regards
Yes, Express supports IE11+ and any other major browser. If there is an issue loading, it is most likely coming from your side of things. You can verify this by visiting our demo in these browsers: https://pdfjs.express/demo
