WebViewer rotation issue
When the sample pdf is loaded in the viewer, it is thought that the coordinate values ​​are rotated.
So, if you draw the annotation with the coordinate value, it is rotated and shown.
Please tell me how to draw it as if it wasn’t rotated.>
  1. Get rotation information
  2. Coordinate transformation according to rotation
    3.Drawing annotation by reflecting rotation
const windowCoordinates = {x:  e.pageX + scrollLeft, y: e.pageY + scrollTop };
const displayMode = instance.docViewer.getDisplayModeManager().getDisplayMode();
const page = displayMode.getSelectedPages(windowCoordinates, windowCoordinates);
const clickedPage = (page.first !== null) ? page.first : instance.docViewer.getCurrentPage() - 1;
const pageCoordinates = displayMode.windowToPage(windowCoordinates, clickedPage);
  newAnnot = new Annotations.FreeTextAnnotation();
  newAnnot.Width = 100;
  newAnnot.Height = 100;
  newAnnot.X = pageCoordinates.x;
  newAnnot.Y = pageCoordinates.y;
  newAnnot.FontSize = fontSize;
  newAnnot.TextColor = new Annotations.Color(0, 0, 0);
  newAnnot.setPadding(new Annotations.Rect(0, 0, 0, 0));
  newAnnot.StrokeThickness = 0;
Sample PDF:
https://www.fsc.go.kr/downManager?bbsid=BBS0030&no=106789
In order to do this you will need to check the pages rotation and set your X and Y values based on that.
To get the rotation you can use the getCompleteRotation API.
If the rotation is 90 or 270 degrees you need to swap your X and Y values.
I hope this helps!
