What is the correct way to enable fullAPI using react
Can not load full API if i add “fullAPI:true” to webviewer constructor i get the following error:
Uncaught (in promise) Error: "fullAPI" is not a valid constuctor option for PDF.js Express. Please make sure you are referring to the proper documentation (https://pdfjs.express/documentation)
Happens with every document
useEffect(() => {
        path: '/webviewer/lib',
        licenseKey: 'my key',
        initialDoc: 'https://path_to_doc.pdf',
        fullAPI: true,
      viewerRef.current
    ).then((instance) => {
      setInstance(instance);
      const { PDFNet, documentViewer } = instance.Core;
      documentViewer.addEventListener('documentLoaded', async () => {
        await PDFNet.initialize();
        fetchMarkups();
For pdf.js express, fullAPI is not a valid parameter and will not work.
If you need to use fullAPI for document manipulation and other features, we recommend checking out Apryse WebViewer.
